hassan yaghi
#1 Posted : Thursday, July 24, 2014 8:08:18 AM(UTC)
hassan yaghi
Dear Martin and all the programming team in VMIX
First of all , I would like to thank you for your efforts making Vmix improvements, Also I want to thank you personally for making the Vmix external output with titles and audio miters as i suggested that it happen in the Vmix 13 , that was surprising . also a thank for making this forum, after all a successful software is where you get suggestion from the users of the software , a little bit of companies do that .
i have tried Vmix 13, all is perfect, one little thing is that vmix 12 and 13 do not support virtual output from another software's , so that's why we still use vmix 11 cause it support all virtual out put on the running machine , we use axel technology xtv suite as a playout software , xtv suite generates 2 virtual outputs , audio and video , vmix 11 reads the output of xtv suite , but vmix12 and vmix13 do not , I hope only a hope that this issue can be fixed.
I thank you all in VMIX and wish you best of luck
Best Regards
#2 Posted : Thursday, July 24, 2014 11:55:39 PM(UTC)
Was thanked: 4719 time(s) in 1617 post(s)
xtv suite only supports 32bit vMix, so you will need to run "vMix" from the start menu instead of "vMix (x64)"
or contact them requesting 64bit support.
hassan yaghi on 7/25/2014(UTC)
hassan yaghi
#3 Posted : Friday, July 25, 2014 9:39:17 AM(UTC)
hassan yaghi
yes we did run 32 bit of xtv suite with 32bit of vmix , all is working fine now . thanks for the TIP .
regards
