pleonardomv
#1 Posted : Monday, October 16, 2023 11:49:52 PM(UTC)
pleonardomv
Brazil
I'm sending text for a title using the example below:
http://127.0.0.1:8088/API/?Function=SetText&Input=877bb3e7-58bd-46a1-85ce-0d673aec6bf5&SelectedName=Headline.Text&Value=Hello
How do I send special characters like Ç, Á, É etc?,
Regards
dmwkr
#2 Posted : Tuesday, October 17, 2023 12:00:35 AM(UTC)
dmwkr
This post comes up when searching the forum for "special characters"... :)
https://forums.vmix.com/...ltiview-input#post105920
pleonardomv
#3 Posted : Tuesday, October 17, 2023 12:33:54 AM(UTC)
pleonardomv
Brazil
I've already tried using the suggested table. It just works with space. If you have a space and put %20 it works, but if you have "Ç" and put %C7 in the title it shows the character "?"
Regards
dmwkr
#4 Posted : Tuesday, October 17, 2023 1:12:39 AM(UTC)
dmwkr
Ok, sorry, hadn't taken a close look at the contents.
This should work, e.g. %C3%87 for "Ç":
https://www.utf8-chartable.de/
or
https://www.w3schools.com/tags/ref_urlencode.asp
pleonardomv
#5 Posted : Tuesday, October 17, 2023 9:07:32 AM(UTC)
pleonardomv
Brazil
or
Thank you very much, it worked perfectly
Regards
