Feature Requests
Option to select which inputs output on which outputs
Now with 2 separate full screen output options and multiple external renderers, would it be possible to set in an input which of the outputs it is enabled for?
For instance, as a simple example using the 2 full screen outputs in program output mode, say I want to have a clean output and then an output with titles. I could go into the title input settings and have it only enabled for the one output I want the titles on so that when I put the title on the program it doesn't go out to the "clean" output, just the output that I wanted to have the title on.
I might have gotten ahead of myself cause I hadn't looked at the settings. I see this does exist for the overlays. I don't have v13 yet though(and i only have the trial in front of me at the moment) so I'm curious if the 2 full screen outputs are independent in this regard?
Joined: 2/18/2014(UTC) Posts: 1,845 Location: Stockholm
Feature Requests
