cody@raceontexas.com
#1 Posted : Friday, October 13, 2023 11:32:40 AM(UTC)
I hope the title says it all. I love the new dials being added for changing the volume for inputs, but would be nice if you could see the percentage or db level that you are setting it to so you dont have to go hover over the slider bar. Kinda defeats the value of it with not being able to see what you are setting the volume to on the stream deck.
mbiliam
#2 Posted : Thursday, October 19, 2023 7:54:41 PM(UTC)
mbiliam
Congo, The DRC
This is exactly what I need. Kindly take me through how it is designed. The bottom up effect in ticker and displaying different time zones
Exp:https://www.youtube.com/watch?v=ywZU0YiWKcg
#3 Posted : Friday, October 20, 2023 4:53:58 AM(UTC)
Just to update this and make it clearer what I would like added. I am wanting the current volume % and db to show up on the touch screen above the dial on the new stream desk + as you adjust it and show it at all times so you can look at it to change the volume vs having to turn the dial and be looking at vmix for the little tooltip to pop up.
