	Feature Requests
	Anchor points - A point of origin
 Joined: 3/11/2014(UTC) Posts: 42 Location: Florida, USA
  Thanks: 6 times Was thanked: 2 time(s) in 2 post(s)
  It would be real slick to have a nine point anchor point (point of origin) for the scale, translate, and rotate of multiviews, like many professional graphics programs have that support these sort of transformations.
  For those of you that may not know what I am referring to, simply put, it can be very frustrating to futz around with multiview scaling and positioning... you make it bigger, then it may no longer be aligned where you want it. Align it, then scale it, and it may no longer be aligned the way you want it. Adding an achor point that says "I want to position and scale based on the lower left corner" makes life easy. Or perhaps, you might want to scale, but you want to zoom in and out from the center. Sweet ey?
  This can easily be accomplished using a 9 exclusive checkbox group (only one can be checked at a time) for:
  [UpperLeft] [UpperMid] [UpperRight] [MiddleLeft] [Center]  [MiddleRight]  [LowerLeft] [LowerMid] [LowerRight]
  And of course, on the programming side, simply concatenate a translation matrix to the indicated anchor spot before applying additional transformations nails it.
  This is as easy as pie from a programming standpoint, and provides the expected usefulness of a professional program.
  Also, if this turns out not to be "as easy as pie", then it provides a proof that the implementation of the matrix math for controlling multi view transformations is incorrect and needs to be redesigned, so this little addition also makes for a good cross check for any implementation bugs.
  I hope you enjoy adding this much needed spit of polish, as I know in advance that the added functionality will truly shine :)
  Joe C. Hecht Code4Sale, LLC
              1 user thanked Code4Sale for this useful post.
 Joined: 5/16/2014(UTC) Posts: 6 Location: Dominica 767
 Joined: 5/13/2014(UTC) Posts: 520   Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
                I agree - that's a useful feature which I certainly make use of when it's available in other applications.
 Joined: 2/18/2014(UTC) Posts: 1,843 Location: Stockholm
  Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
                +1 sounds useful, even though I have not yet run into the problem (but likely will, unless... ;)
  Thanks: 8 times Was thanked: 8 time(s) in 7 post(s)
	Feature Requests
