fgolman
#1 Posted : Thursday, September 14, 2023 3:05:09 PM(UTC)
fgolman
Would love to see a trigger for start and stop of recording. Would be very useful to add additional functionality when these two actions are taken, such as turning on or off external tally following the condition.
#2 Posted : Thursday, September 14, 2023 5:09:02 PM(UTC)
https://forums.vmix.com/...ng-for-Dummies#post71124
fgolman
#3 Posted : Tuesday, October 10, 2023 7:50:57 AM(UTC)
fgolman
Although that script is useful and does what I need but I've found it to be unreliable, often getting stuck, randomly stopping or something. Of course, the only way my team realizes it is when it isn't working!
SO, the request still stands and would be something quite useful to get integrated rather than as a tack-on approach.
#4 Posted : Tuesday, October 10, 2023 9:54:50 AM(UTC)
Although that script is useful and does what I need but I've found it to be unreliable, often getting stuck, randomly stopping or something. than as a tack-on approach.
Maybe show us what you changed in the script to have it behave like you say (or something)
Never had such behaviour myself
nikosman88
#5 Posted : Tuesday, October 10, 2023 10:17:05 AM(UTC)
nikosman88
Greece
Personally i have found out that sometimes scripts that loop, even if we stop them they continue to work, even if in vmix script menu seem to be stopped. This bug is not easy re-producable but happened to me 4-5 times at the 3 about years im using vmix. It happened first at v24 but it also happened august 2023 last time in v26 version.It has not to do with the kind of script if it vb net script or vmix api commands only. It is solved if you restart vmix but in a live show, not to comfortable to do a restart.. It has also mentioned here https://forums.vmix.com/...x-26-Released#post109344 and i hope in the up-coming v27 this is solved.
Other than this problem, i have no problem with vmix script.
nikosman88
#6 Posted : Tuesday, October 10, 2023 10:20:17 AM(UTC)
nikosman88
Greece
+1 triggers have to be updated. Also i think it would usefull to add shortcuts for enable-disable a trigger in a input. Trigger manager that allready exist is a good step but it would be better if we had also shortcuts for enable-disable
fgolman
#7 Posted : Tuesday, October 10, 2023 10:50:14 AM(UTC)
fgolman
+1 on shortcut to enable and disable. Love to also get an auto start other than using a web page call in the preset that does the URL to the run function.
Guest (7)
