I have a vmix desktop computer that has a Avermedia capture card. Our Win11 laptop is connected to the capture card via an HDMI cable. If I play a video on the laptop, I am able to see the video in a vmix input, but no matter what I do, I cannot get the audio. Is it possible to get video and audio from HDMI? If so, what am I doing wrong?
Thanks: 5 times Was thanked: 20 time(s) in 19 post(s)
if you play the video on the laptop and you can hear the sound out of the laptop speakers that probably means the default audio device on the laptop isnt HDMI.. if so, try looking at audio output settings and selecting HDMI as the default device..
On my laptop there are two audio outputs in Windows: Speakers and nVidia (the video card), but no HDMI choice. I can play the video with the HDMI plugged in and I can hear the audio from the laptop. If I switch the audio to nVidia, the audio (from the laptop) is silent. I assume this is the correct setting for Windows (on my laptop). In vMix, there is no HDMI choice. This is in settings; audio output. There are several choices here, and I tried all of them, but no audio from the laptop is seen. Any suggestions?
Originally Posted by: JohnnyBG  On my laptop there are two audio outputs in Windows: Speakers and nVidia (the video card), but no HDMI choice. "nVidia" is probably the device which generates the HDMI output, so it would normally be the appropriate choice to get the computer audio to play out via the HDMI o/p rather than through the (normal) speakers/headphone o/p. Originally Posted by: JohnnyBG  In vMix, there is no HDMI choice. In vMix, the HDMI input will be provided by a captured device of some sort, which as far as I can tell you are already selecting in order to see the video. It may be that there was no audio on the laptop HDMI output when you created the input, which is why the audio subsequently doesn't show up even when you change the setting on the laptop. First step, if it were my setup, would be to check the laptop HDMI by connecting it to a normal TV (which has built-in speakers) so you can hear whether the audio is present. Then connect the HDMI cable to the capture device on the desktop, remove the existing HDMI capture input in vMix and add it again (or select change to reselect it from the available devices) and make sure that it's showing audio as available. Finally, make sure that the audio is enabled (and not muted) for that input.
Zenvideo - I think you are correct. The laptop HDMI was not activated when the vMix input was created. I removed it and created a new input with the laptop HDMI active. vMix created an audio input in the audio mixer and I now have control over the HDMI audio and video. Thanks for the help.
