GT
Increasing value in gtzip from.script
Joined: 4/2/2013(UTC) Posts: 53  Location: Hungary Thanks: 3 times
I have a title in Gt Title wich called test.gtzip.
In this. Title there is a line wich called Number.
How can I incrase the value of this line?
I tried the API, but it isn't work.
Thank you.
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Joined: 9/5/2020(UTC) Posts: 38  Location: brisbane Thanks: 2 times
what are the increments you want to step up in?
Originally Posted by: doggy  Thank you. I tried write script, but I got error message from Windows (in hungarian language). Can you show me the correct script if I show You my Vmix projects? Sorry for the late reply.
Originally Posted by: adambou  what are the increments you want to step up in?
Thank you for yor question. I would like to increase it one by one. I tried several examples but got an error message. Unfortunately I don't know the correct syntax.
Populate the field by a data source, in the data source have a list of numbers in the increments you need. Write a script that will select the next row of the data source when you want to increase by one.
Joined: 1/25/2019(UTC) Posts: 334  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
when doggys proposals not working, do you have a 4k or pro version? only these supporting scripting. otherwise see also HEREthere is a proposal to change numeric values via shortcut EDIT: I fell into the trap of responding to a 2-year-old post :-) Sorry about that.
GT
