Hi, we have a machine with vmix that is unable to boot into windows, fortunately I was able to obtain all vmix related data from the aforementioned computer including the executable, program files, and assets.. Is it possible to transplant these files to another instance of vmix in some way that i don’t lose all my precious presets and configs? lesson learned. thanks in advance.
Rank:: Advanced Member
Joined: 12/24/2021(UTC) Posts: 733  Location: athens Thanks: 166 times Was thanked: 98 time(s) in 94 post(s)
Originally Posted by: alwaysbackup  Hi, we have a machine with vmix that is unable to boot into windows, fortunately I was able to obtain all vmix related data from the aforementioned computer including the executable, program files, and assets.. Is it possible to transplant these files to another instance of vmix in some way that i don’t lose all my precious presets and configs? lesson learned. thanks in advance. Vmix has a config file that store many settings. To find it,you must enable show hidden files go to c drive folder called users for example C:\Users\name of your pc\AppData\Local\StudioCoast_Pty_Ltd and inside it you will find a folder with version name of vmix and a config file. In the new install of vmix try to copy/replace this config file and if work, you will have back all your settings.
Thank you lots for your reply, is there currently a method for downloading an earlier version of vmix?
Joined: 11/19/2015(UTC) Posts: 30  Location: Netherlands Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
Latest full releases (23, 24, 25) are available from the vmix download site (https://www.vmix.com/software/download.aspx). Scroll down till you see releasnotes for older versions. There is also a download link. If yo need a 26 version, check your documents folder, each upgrade is saved in Documents.
Otherwise i have same 26 versions saved here and there.
