Joined: 3/30/2023(UTC) Posts: 126  Location: Chicago Thanks: 11 times Was thanked: 6 time(s) in 5 post(s)
Is there a way to set vMix so that the functionality of the tiny Direct Cut button on each source could also work by merely clicking the input itself (obviously, right now that sends the source to preview)? The need is for a touch screen remote to more easily run the show. I realize that we can do this with a web panel but the idea is just to do it from the actual UI since we've already got that up via Splashtop.
I did a search and maybe it's just my parameters but not finding this as a topic that's been discussed.
Thank you.
Fritz Golman iHeatMedia
Originally Posted by: fgolman  Is there a way to set vMix so that the functionality of the tiny Direct Cut button on each source could also work by merely clicking the input itself (obviously, right now that sends the source to preview)? The need is for a touch screen remote to more easily run the show. I realize that we can do this with a web panel but the idea is just to do it from the actual UI since we've already got that up via Splashtop.
Thank you.
input configuration-> mouse click action https://www.vmix.com/hel...nputSettingsGeneral.html
Joined: 11/23/2020(UTC) Posts: 252  Location: Wichita Thanks: 14 times Was thanked: 32 time(s) in 28 post(s)
Originally Posted by: fgolman  Excellent, thank you!
Of course there's ALSO the "CUT" and the "Quick Play" buttons on every input which will directly switch to that input without going to preview first.
