Joined: 1/21/2021(UTC) Posts: 8  Location: Whitley Bay Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Hi All I use to use a system that allowed me to route vmix calls to other vmix calls without the Guest having to do anything at their end and it worked well but is now no longer supported. This meant I could have callers come directly into a green room on my vmix system to be prepped and then 'switched' over to another vmix system for the live panel. I have looked at other call management systems (Gnural net, RProducer) but they don't appear to 'route' vmix calls which is what i need. Anybody know of anything else that may do this?
Joined: 10/13/2020(UTC) Posts: 6  Location: Phoenix Was thanked: 1 time(s) in 1 post(s)
What was the system you were using to route calls?
Rproducer is likely the closest thing. It’s been a while since I used it but I think you can move someone around from one call slot to another.
I guess there is nothing available. But some thoughts from my side #1 New zoom integration with v27 #2 video ninja #3 MS Teams as greenroom -> NDI or SRT into vMix #4 Medialooks VT
Just to give you some options.
