sdonn
#1 Posted : Tuesday, September 12, 2023 8:22:28 AM(UTC)
sdonn
I have managed to add a list of 5 MP3 files, then shuffle them using a trigger in a seperate input and then play the list input as part of the Playlist (effectively a randomised choice of music). This works fine when I put the list input in a Playlist and start it.
However when I try add a different input (eg a video sequence) and add a trigger OnTransitionIn. Play. List (then the name of the list), then it shuffles the list but continues to play the song that it was on. I have set it to play the first item in the list but it always carries on playing the one it was on.
That's probably as clear as mud, but if anyone can throw some list why list shuffle and play works when adding a list in a Playlist, but does not work when trying to play a list within a trigger, then that would be amazing. Thanks
Guest (4)
