Hardware Compatibility
4 Channel SDI Audio Input support
Thanks: 8 times Was thanked: 3 time(s) in 3 post(s)
Hi all I have a Canon XF205 with 4 channel SDI audio support Can vmix support 4 channel SDI audio from one camera?
SDI Supports up to 16 audio channels. vmix can handle all 16 Channels if your capture card supports it
Originally Posted by: calihc  SDI Supports up to 16 audio channels. vmix can handle all 16 Channels if your capture card supports it but only 8 on Black Magic devices
Thanks for the tips
I was wondering about the capture device.
I'm using Blackmagic UltraStudio Recorder 3g, No idea how many channels this device supports.
 I wonder why its not showing up
Any tips how I can fault find the problem?
I'm expecting to see 4 channels? Is this correct?
I think I have it sorted now, Channel mixer is what I want. Its not very intuitive
Thanks: 5 times Was thanked: 2 time(s) in 2 post(s)
I was hoping that this might have been resolved by now? 4 Channel audio is not un common and having to go into channel mixer to alter things is not at all fast in a production environment. It there no way to allow the 4 channels to show on the audio display ?
