Hi there! I have been looking for this feature for a long time. I would love to be able to make a rundown in Google sheets, that could trigger Vmix actions (in combo with the existing data source function Vmix already has). There are a couple of products out there that do rundown based triggers, like Cuez and Central control, but both are not real options. Cuez ( https://cuez.app/ ) is great but extremely expensive and Central Control only works on timed basis. So you have to plan out your show to the minute and you can't select and trigger rundown events by manually selecting a row or column. When looking at the options for triggers in Google Sheets nowadays ( https://spreadsheet.dev/triggers-in-google-sheets ) something like this must be possible. Who got any ideas?
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Ruben Blammo  Hi there! I have been looking for this feature for a long time. I would love to be able to make a rundown in Google sheets, that could trigger Vmix actions (in combo with the existing data source function Vmix already has). There are a couple of products out there that do rundown based triggers, like Cuez and Central control, but both are not real options. Cuez ( https://cuez.app/ ) is great but extremely expensive and Central Control only works on timed basis. So you have to plan out your show to the minute and you can't select and trigger rundown events by manually selecting a row or column. When looking at the options for triggers in Google Sheets nowadays ( https://spreadsheet.dev/triggers-in-google-sheets ) something like this must be possible. Who got any ideas? If they need to be data driven triggers, just read them with a vMix vb.net script and act accordingly
Joined: 6/23/2017(UTC) Posts: 29  Was thanked: 10 time(s) in 6 post(s)
You can actually advance through Rundown events in Central Control now using the go button. I use it on a production I do to step through the key parts of the show.
Joe
Joe Hoi Joe. Is this a update from since i mailed you on the 8th of June? Because a 'go' button was on my suggestions list. That would be great!
You can fully remote cotrol vMix through the web API.
