Hardware Compatibility
Asus Rog Strix Ryzen 9 stuttering
Hello everyone. I have been having problems with a 4k project that has more than 5 external inputs (4k capture card and NDI4k). Vmix is unable to smoothly process the video from these inputs. My CPU and GPU are only at 40% according to the Windows Task manager.
I have a ROG Strix Laptop Ryzen 9 RTX 3080 32GB RAM 2TB SSD.
All settings in Nvidia are set to RTX (global settings in Windows) and high-performance power mode as well.
However, even with these settings, in 4k projects, I can't have more than 4 inputs because it starts to stutter, despite the low CPU and GPU usage.
Any tips?
Joined: 2/5/2021(UTC) Posts: 38  Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
Did you resolve this?
Is this a laptop? Did you try Resizable BAR?
Hi there, I have the same problem with ASUS ROG Strix gaming laptop / CPU 3.3 GHz AMD Ryzen 9 6900HX with Radeon Graphics / Second GPU NVIDIA RTX3070 ti/ The issue with video capture lag started in March 2024 and I can not fix it (moving to the old driver did not help which surprised me a lot). Does anyone have the same or similar issue? Can anyone help? (No resizable bar) - Display is set on 1920x1080 60Hz.
Cheers Miles
Joined: 10/20/2023(UTC) Posts: 166  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
Originally Posted by: filipe_aguilera  Hello everyone. I have been having problems with a 4k project that has more than 5 external inputs (4k capture card and NDI4k). Vmix is unable to smoothly process the video from these inputs. My CPU and GPU are only at 40% according to the Windows Task manager.
Any tips? Which capture cards are you using? If it's 4K30p, it's likely USB 3.0, so it's probably a USB bandwidth issue. On the ASUS ROG Strix, there are only three USB-A 3.0 ports and one 10 Gbps USB-C port; the two USB ports on the left side of the laptop likely share the same controller, so you should only plug in one capture card there. Try connecting a card to the USB-A port on the back of the laptop, and also try using a 10 Gbps USB-C hub (with external power and a VIA VL822 chip) with two USB capture cards. That will reveal the limitations of your laptop's USB ports.
