Joined: 10/14/2016(UTC) Posts: 65 Location: Sheffield
Hi all, hopefully someone can help here. We have a script to control a bunch of stuff on the main show PC and a secondary PC as well. Sadly it seems that we hit some kind of buffer with the commands to the secondary PC. If I hit the button a few times it then goes to "running" and won't continue doing anything. The script is:
Dim client = WebRequest.create("http://10.0.0.4:8088/API/?Function=MultiViewOverlayOn&Input=1&Value=1") Dim response = client.GetResponse() response.Close sleep(100) Dim client1 = WebRequest.create("http://10.0.0.4:8088/API/?Function=MultiViewOverlayOff&Input=1&Value=2") Dim response1 = client1.GetResponse() response.Close sleep(100) Dim client2 = WebRequest.create("http://10.0.0.4:8088/API/?Function=MultiViewOverlayOff&Input=1&Value=3") Dim response2 = client2.GetResponse() response.Close
I put the "sleeps" in to try and reduce the burden but to no avail.
Ideas on a postcard please!!
I'm assuming nobody has an answer for this one...
Thanks: 12 times Was thanked: 33 time(s) in 28 post(s)
Does it help not closing 3 times "response"?
As the script stands it just locks it up after a couple of starts
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Originally Posted by: nomski  As the script stands it just locks it up after a couple of starts I think pm means, that you are closing 'response' three times, but 'response1' and 'response2' not at all.
For example, this is a good test script for it: Dim client = WebRequest.create("http://10.0.0.53:8088/API/?Function=OverlayInput1In&Input=1") Dim response = client.GetResponse() response.Close sleep(1000) Dim client1 = WebRequest.create("http://10.0.0.53:8088/API/?Function=OverlayInput1Off") Dim response1 = client1.GetResponse() response.Close sleep(1000) Dim client2 = WebRequest.create("http://10.0.0.53:8088/API/?Function=OverlayInput1In&Input=1") Dim response2 = client2.GetResponse() response.Close sleep(1000) Dim client3 = WebRequest.create("http://10.0.0.53:8088/API/?Function=OverlayInput1Off") Dim response3 = client3.GetResponse() response.Close
If you run this a couple of times, it breaks. You can then wait a few minutes and it starts working again. Very odd!
Originally Posted by: dmwkr  Originally Posted by: nomski  As the script stands it just locks it up after a couple of starts I think pm means, that you are closing 'response' three times, but 'response1' and 'response2' not at all. I see. I'll give that a go.
Assume you are trying it with a webrequest because you are controlling another computer as else you just could use the APi.Functions?
Webrequests do take some time to finish (if at all) , have you tried one at a time ( step by step debugging) and trying not to start the script again before being shure it has executed completly ?
Always a good idea to build in error traps within a script !
Yes, controlling another PC. It seems that it's a rate of request thing that does it. If I just do one command it works. If I then bash the one command script a bunch of times, it breaks. If I have 3 or more web requests it breaks. It still responds if you run the same web request from a browser though which seems odd!
SORTED!! Thanks so much. It was the not closing the responses correctly. Happy days!! That was driving me nuts.
