So,
(The setup) I have two sets of two PCs that all are running vMix. Each PC in the set has a different role. PC 1 is bringing in two 1080i60 feeds over SDI via a Decklink Duo 2, has 10-15 video elements, some multiviews, an NDI feed with alpha from the second PC which is overlayed on both Decklink Duo inputs via multivew, and is running a light continuous script. PC 1 also outputs via a Decklink Mini Monitor HD. PC 2 has about 50 different GT titles and runs a heavy continuous script. There is a PCI-E network card in PC 1 and PC 2 that is connected directly via a CAT 6, NDI is running through this.
All PCs are Ryzen 7 3800x, RTX 2060 or 3060.
(The issue) Every few minutes, both video and audio will stutter, some times are worse than others. The weird part is both PC set 1 (set of two PCs outlined above) and PC set 2 (another set of two) stutter at the same time in a similar pattern. It stutters regardless of what is in program, Decklink input, MP4 file, MP4 file via a list.
(Troubleshooting so far) Each set is on a separate circuit and UPS, still stutter simultaneously. Ran a CPU stress test to see if stutters would get worse, didn't. Updated graphics drivers, no change. Statistics tab shows many dropped frames in NDI input, but if I force NDI to drop by disabling network adapter, no stutter.
Of course ask questions. It would make me very happy to see this resolved!
Update on this for those that may for some odd reason run into this same problem.. We found the cause of this to be a data source pointing to an Excel file with 100 rows that, because of caching, had grown to about 15 MB. Every time this file was updated, it caused a stutter/dropped frames and audio. Since the file kept growing, the problem just kept getting worse.
So the solution was to create a new Excel file and copy over all the rows which shrunk it to 15 KB.
