Feature Requests
Hide PRV/PGM on Main window when MultiView is active
Joined: 3/18/2021(UTC) Posts: 45   Location: Tokyo Thanks: 19 times Was thanked: 14 time(s) in 11 post(s)
Hello, we are using duplicated vMix multiview for production room for crews. but in main window, we dont check Program/Preview when we can check multiview. I am willing to check many input in "input bars", so I want new option like "hide PRV/PGM on main window" if possible!
+1 and it also would be helpfull, if we can disable the PRV/PGM in multiview, because we have PRV/PGM on separate Monitors, so we don't need it
Joined: 2/23/2019(UTC) Posts: 139  Thanks: 20 times Was thanked: 29 time(s) in 26 post(s)
+1 for both the above
Use case: using one vMix instance (cut) for bringing in cameras and mixing audio then sending 4 mixes to a second instance (prod) to do the main production. preview and program don't mean much on the cut machine and the screen space, on the main window and multiview, would be better used for showing more/larger camera previews.
Feature Requests
