(issue) browser link not saved in preset
Rank: Guest
Groups: Guests
hi guys, possible issue founded,
recently i needed to change a link on a browser input, saved the preset before close but when i open the preset, browser input doesn't open the new link.
also, i found a workaround for this, i opened the preset on notepad and changed manualy the link on browser input, so then it worked.
Joined: 3/7/2012(UTC) Posts: 2,691  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ melody,
Did you "Change" the Input or just the URL? The vMix Preset saves the "original" URL of the Browser Input, not a changed or updated one, you need to actually "Change" the Input for that (cog wheel ===> General tab ===> "Change" button).
Rank: Guest
Groups: Guests
i changed the url of the browser input and saved the preset
@ melody
That will not save the new URL in the Preset as it is still the original Browser Input which is saved with the original URL, you need to use the "Change" button to add a new Browser Input with the new URL if you want that new URL to be saved in the Preset.
Rank: Guest
Groups: Guests
ok, i understand the logic behind, but it realy doesn't make sense the need to change the entire input just to save the new url on preset, so i sugest some fix for it.
