I hope someone can help me with the following problem in vMix. I have created an option in vMix that I stream via Youtube Live Stream Now. When I start streaming, you will see 2 live streams appear in my channel, both with the same title that I made in Youtube settings, one tile has the banner of my channel as a thumbnail and the other the opening image. I find it strange that 2 tiles are created, one tile also stops after a few minutes. What will i do wrong?
Just use custom RTMP in the stream profile and setup your event manually. Yes, manual processes sucks a bit but if you want to be in control it's the way to go. Also check that the second and third stream is deactivated or used as the backup entry point
 1 user thanked mavik for this useful post.
Thank you very much for your response - it's great that you think along. We use vMix for our church services - here we broadcast on 2 channels, the first channel is a channel for churches, the other is Youtube. Yesterday we discovered that starting streaming, after streaming via Youtube for 7 minutes, the streaming turns orange, then it stops and a little later it continues again. You can see on Youtube that he keeps searching. I hope again for your valuable comments.
Joined: 8/16/2019(UTC) Posts: 357  Thanks: 80 times Was thanked: 24 time(s) in 19 post(s)
I had that, so I reduced my output to 3mb for both Facebook and YouTube and it worked perfectly.
