3rd Party Software and Development
Title text not updating on graphic from script but is in editor
I have a scoreboard that i am controlling the values of from title editor via scripting adding +1 and +2
all is functioning ok but sometimes the numbers do not display sequentially
eg. in title editor the value is 100 but on the input in the text source is says 98, on the next button press to run the +1 script it then goes to 101
really random and a bit of a headscratcher
Is there any way to force refresh the title text at the end of each script?
Originally Posted by: Streaming_solutions  I have a scoreboard that i am controlling the values of from title editor via scripting adding +1 and +2
What is the title structure (field names) and what is your script code ? fwiw never have encountered such issue
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
As doggy mentioned, this is not possible. Only if you send the command multiple times, because of a bad keyboard or leaving the finger too long on the button. Test it, with an external usb keyboard parallel to the existing one. You don‘t need a script, use the text change shortcut and put +1 in the value field.
