elPoohy
#1 Posted : Wednesday, August 9, 2023 7:28:36 PM(UTC)
elPoohy
Cyprus
Hello everyone.
I have a multiview in which one layer consists of different media sources. They can have any aspect ratio from 16:9 to 9:16. But they all need to fit into a rectangular area. How can I set up automatic fitting to the inner boundaries of this area? I thought about writing a VB script but didn't understand how to get the resolution value of the media file for a specific input. This information is not present in the current status XML.
Is there a way to configure this using standard tools or to retrieve this information in a script?
#2 Posted : Thursday, August 10, 2023 9:03:17 PM(UTC)
Originally Posted by: Bonbondotkom Go to Quoted Post
Originally Posted by: elPoohy Go to Quoted Post
Hello everyone.
try posting your question here:
https://forums.vmix.com/posts/t20986-Scripting-for-Dummies
Useless response ;-)
Just use a simple virtual set with a UVMAP. Source will fit into the map , check with the "Demo UVMap VirtualSetWorks "set
Bonbondotkom on 8/14/2023(UTC)
elPoohy
#3 Posted : Thursday, August 10, 2023 10:38:40 PM(UTC)
elPoohy
Cyprus
Hello everyone.
But UVmap didn't help. If I create map of rectangular shape I will cut everithing that outside of UVMAP area (
#4 Posted : Friday, August 11, 2023 12:24:55 AM(UTC)
I dont know how you created the UV map or modified it but if one has a standard screensize UVMAP any input assigned to should be inside it !
elPoohy
#5 Posted : Friday, August 11, 2023 12:36:02 AM(UTC)
elPoohy
Cyprus
Yes. But my problem come to life when I need nonstandard screensize. I need my inputs to be bounded to the rectangular (almost square) arena.
mavik
#6 Posted : Friday, August 11, 2023 3:18:54 AM(UTC)
mavik
Was thanked: 197 time(s) in 177 post(s)
Is a mask working in your case then? You can have a special shape mask and use whatever input. It wouldn't resize the input but allow a special predefined shape.
elPoohy
#7 Posted : Friday, August 11, 2023 5:40:40 AM(UTC)
elPoohy
Cyprus
Yes. But, as You say, it doesn't resize. That main issue with vMix.
Bonbondotkom
#8 Posted : Monday, August 14, 2023 11:30:02 PM(UTC)
Bonbondotkom
Philippines
Hello everyone.
First of all, apologies for the "Useless Response". just store a custom xml in DynamicValue that stores the info you need, then pull data from that using VB.
here's an example from the StreamingAlchemy Show
https://github.com/StreamingAlch...ain/SA-S02E07/SetBox1.vb
Code:
Dynamic1Val = "<Slots><Slot1>A</Slot1><Slot2>B</Slot2><Slot3>C</Slot3><Slot4>D</Slot4></Slots>"
    API.Function("SetDynamicValue1", Value:=Dynamic1Val)
Code:
dim Dynamic1Node As XmlNode = VmixXML.selectSingleNode("/vmix/dynamic/value1")
dim SlotXML as new system.xml.xmldocument
    SlotXML.LoadXml(Dynamic1Node.InnerText)
    Slot1Guest = SlotXML.selectSingleNode("/Slots/Slot1").InnerText
    Slot2Guest = SlotXML.selectSingleNode("/Slots/Slot2").InnerText
    Slot3Guest = SlotXML.selectSingleNode("/Slots/Slot3").InnerText
    Slot4Guest = SlotXML.selectSingleNode("/Slots/Slot4").InnerText
Credit to:https://www.youtube.com/@StreamingAlchemy
elPoohy
#9 Posted : Friday, August 18, 2023 8:00:37 PM(UTC)
elPoohy
Cyprus
Thank You, for your answer.
But that also not an automatic. You need to manually enter resolution. But when You on news show sometimes You only have 10 seconds for import media to vMix, before have it live.
