NDI
NDI Audio output sample rate different from vMix master sample rate
We are running into an issue where the audio input and master sample rate in vMix is 44100 but the NDI output from vMix is 48000. It's causing a pitch adjustment. We want to have everything 44100 to troubleshoot some other issues, but can't seem to get our NDI output to match these settings. Any ideas?
Have you tried the master sample rate in the audio settings?
Yes. Master sample is set to 44100 but NDI output is 48000. I'm noticing that the NDI output also appears to be 30fps even though everything is set to 60fps.
NDI
