Stream Delay (new vMix 26 feature)
Joined: 12/4/2016(UTC) Posts: 18   Location: Strasbourg Thanks: 3 times
Hi everyone !
For the broadcast of an Esport Event in August, I will use 900 secondes (15 minutes... yes very long !) "Stream Delay". This is requested by the event organizer to avoid cheating. I already tested such a delay during a 1 hour test event and so far so good.
But now there's a question when the show is over : what is the best way to stop automatically the stream without losing video buffer ? A simple click on the stream button is bad as you lose the last 15 minutes of the show ! So : - use a chronometer and click manually on "stop " ? Big fun. - create a shortcut that will automatically stop streaming after 900 seconds ? How to do this ? - other way ??
Thank you very much for any answers ! Regards.
Hello. You can make a script like this sleep (900000) API.Function("StopStreaming", Value:="1")
Assign it to shortcut,that you will run it when needed and wait for the rest..
Thanks a lot @nikosman88 ! I use your script / assign to shortcut and it works well ! Small correction though : API.Function("StopStreaming",1)
Joined:: 7/4/2021(UTC) Posts: 430  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Ending a stream like this, with or without the delay, is generally not recommended, because latency can present issues.
The commands to start/stop the stream aren't sent on the same timeline as the stream itself. So if the server you're streaming to is processing your video with, say, a 1 second delay, stopping the stream the moment it's over from your end will generally kill that stream and drop that last second.
That's why a lot of streams will have those "Thanks for watching" or whatever title cards up at the end for a minute or 2 before killing the stream.
Hi WaltG12 and "Thanks for helping" ! :-)
