Joined: 5/11/2023(UTC) Posts: 3  Location: Minas Gerais Thanks: 2 times
I would like to know if anyone has experienced this problem I have been facing.
I have an input with a playlist and in its proprieties I leave the audio set to +8dB. After playing a few files from that playlist, the gain goes back to 0dB on its own. I also noticed that if I make any changes to this dedicated input in the playlist itself, such as graphic equalizer enabled, after running some files it goes back to the default, which is disabled.
Is there anything I can do to make this input to keep this audio gain without going back to the default settings?
Thanks in advance.
Joined: 5/15/2022(UTC) Posts: 19  Location: Ohio Was thanked: 2 time(s) in 2 post(s)
Not sure if this will fix your issue, look to see if "automatically mix audio" is checked in the setting menu for your input. If this is checked, any audio commands you have in the "triggers" section are ignored and the audio just mixes automatically. This might also be the reason the audio level is returning to 0dB.
