Feature Requests
Add datasources in vmix Preset Bundle
Joined: 4/8/2019(UTC) Posts: 21  Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
When creating a bundle Preset, datasource references are included in the preset, but not the datasource files themselves. it would be great it that files could be also added to the bundle Vmix create.
If the datasource is based on a local file it would. But what if it's based on a xml or google sheet online?
 1 user thanked mavik for this useful post.
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: mavik  If the datasource is based on a local file it would. But what if it's based on a xml or google sheet online? or local network that can be different when setup on diff event location
Originally Posted by: mavik  If the datasource is based on a local file it would. But what if it's based on a xml or google sheet online? In that case you can have the reference url in the preset, and just need to refresh credential to access file if needed.
Originally Posted by: doggy  Originally Posted by: mavik  If the datasource is based on a local file it would. But what if it's based on a xml or google sheet online? or local network that can be different when setup on diff event location In that cas, Vmix should be ok by changing the path to the file when loading the preset bundle. For example : in my source preset, file was on f:\myfiles\datasource.xlsx I want to save my preset as a bundle : Vmix save that datasource file in the preset When loading the preset, vmix reference the datasource files (other than url defined files) as local to the bundle, or could propose to store that file somewhere where the computer has access.
Feature Requests
