Feature Requests
Ability to remove first "0" from countdown clock
Joined: 2/14/2023(UTC) Posts: 2  Location: Black Mountain, NC Thanks: 2 times
For our AUDL (American Ultimate Disc League), we have roughly 150+ games a season and with the exception of those who have automated score bot systems, we are need to use the built in clock countdown feature within a GT Title. With a 12 minute per quarter clock, when it reaches under 10min, there is a front "0" we would love to NOT have present - ie 09:59 is less attractive in than being able to simply have 9:59.
Joined: 4/23/2017(UTC) Posts: 1,491  Location: Germany Thanks: 3 times Was thanked: 198 time(s) in 178 post(s)
I couldn't find something like m:ss preset either and its a bit understandable when you would use that m:ss and you set the counter 10 minutes it would display 0:xx for the first minute. The only thing I can see is a graphical approach. When the counter is in the single digit minutes a graphic is added above the leading 0 to make it just visually "better".
Originally Posted by: luketimjohnson21  For our AUDL (American Ultimate Disc League), we have roughly 150+ games a season and with the exception of those who have automated score bot systems, we are need to use the built in clock countdown feature within a GT Title. With a 12 minute per quarter clock, when it reaches under 10min, there is a front "0" we would love to NOT have present - ie 09:59 is less attractive in than being able to simply have 9:59. One can add the m:ss format to the user.config file of your current instalation of vMix. It will then appear in the dropbox to select from. Any other "special" formatting can be done using scripts
 2 users thanked doggy for this useful post.
Originally Posted by: doggy  Originally Posted by: luketimjohnson21  For our AUDL (American Ultimate Disc League), we have roughly 150+ games a season and with the exception of those who have automated score bot systems, we are need to use the built in clock countdown feature within a GT Title. With a 12 minute per quarter clock, when it reaches under 10min, there is a front "0" we would love to NOT have present - ie 09:59 is less attractive in than being able to simply have 9:59. One can add the m:ss format to the user.config file of your current instalation of vMix. It will then appear in the dropbox to select from. Any other "special" formatting can be done using scripts You`re right. This file can be found at c:\users\ourpcname\AppData\Local\StudioCoast_Pty_Ltd will be a folder vmix and inside it the user.config that can be opened for example with notepad.exe. In this file we will search for <setting name="CountdownFormats" serializeAs="Xml"> and beyond the other options we will add this <string>m:ss</string> save the file,open vmix and now you`ll have the option to do this way of timer
 1 user thanked nikosman88 for this useful post.
Feature Requests
