Joined: 2/17/2012(UTC) Posts: 20  Location: Netherlands Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
I need help desperate this is the 3 time something again going wrong on the same every year project. And think about to quit this struggle to buggy, this after 3 years building shaving and investing thousands of euros i have still a useless machine. in short i have now 2 hv 30/40 canon. hdmi to sdi with atomos portable, sdi recorders blackmagic. i5 12 gb and 2 ssd samsung pro. and i got this ... as reward?!  i do not know what to ...
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
Could you post the results of the log files here. The results from a working recording and a broken recording would be best.
I would like to get to the bottom of this, but I need as much information as possible.
Martin vMix
Martin,
If i have time and acces to the file ill send them to you.
Thaks in advance,
Richie
Thanks for the file information.
"Decklink Audio Capture #2" does not support being selected directly by the recorder. Instead your setup should be as follows:
1. In vMix Settings under the Audio tab select "vMix Audio" as the recording device. 2. When adding the Decklink Video Capture 2 input, select the audio there instead.
Martin vMix
