Joined: 9/29/2021(UTC) Posts: 8  Location: California Thanks: 3 times
Hello Richard,
Our church has three microphones for our speaker, choir, and pianist. How to create a microphone button that toggles audio on and off by pressing the same button on the Apple table. I don't create any audio buses for these microphones. I am using vMix Panel Builder 4.0.59 for window and sink to an Apple table.
Thank you so much.
Rebecca
Rank:: Member
Joined: 7/1/2023(UTC) Posts: 16  Location: Bridgetown Thanks: 2 times
Add a button, set it to work with the AUDIO, and when you press that button, it should toggle on/off....then go to the ipad, and copy that Template, and the button....it should work if you do it correct....
