Reattach Audio Mix Pallette
Joined: 7/8/2023(UTC) Posts: 21  Location: Great State of Tennessee Thanks: 12 times
I had detached the audio mix with the pin button, but now I want to reattach to the default position. When I click the minimize button it brings up a bunch of grids for location.... but I am not finding any of them that reattach to the default location. I am trying to follow the instructions on this page with no success: https://www.vmix.com/help25/index.htm?Mixer.htmlPlease advise on what I am missing. Thanks
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ talkinlive
Something does not sound right with your system. The minimize button should return the window to the pinned position within the UI. Have you tried rebooting the computer to clear any possible errors it is encountering?
Thanks, you were right. I had to reset Vmix to default and it works again.
