Joined: 7/9/2023(UTC) Posts: 2  Location: Arizona Thanks: 1 times
Hi, I am looking to build a vmix machine that us primarily going to be used for only vmix calls. It will not have camera inputs or NDI inputs. There will be video and graphics usage but no video inputs. As such I was wondering which recommendations for a vmix machine should be followed and which might be able to be fudged a bit. I am on a pretty tight budget and looking for margins where ever I can find them.
you just build a computer with a good NVidea graphics card, and install vMix.....There is such thing as a vMix machine.....any computer can be what you want it to be... I run vmix on a cheap PC with a good graphics card, and no issues
Sweet I had just seen their recommendations for systems and was wondering how closely they would need to be followed if you're not using all the bells and whistles.
