Changing Input Name Using Script
Joined: 11/2/2018(UTC) Posts: 44  Location: Blantyre Thanks: 6 times
Is it possible changing an input's name to something else using a script ? If it is possible would someone share it?
Thanks in advance.
Originally Posted by: Fountain Kamanga  Is it possible changing an input's name to something else using a script ? If it is possible would someone share it?
Thanks in advance. Please check out the available input shortcuts ( the name is very obvious) . a shortcut function = an avaiable script function
Originally Posted by: doggy  Originally Posted by: Fountain Kamanga  Is it possible changing an input's name to something else using a script ? If it is possible would someone share it?
Thanks in advance. Please check out the available input shortcuts ( the name is very obvious) . a shortcut function = an avaiable script function Thanks I have been struggling for hours, this worked. I was looking under Title shortcuts. Thank you very much.
