Playout multiple DIFFERENT videos to different sources
I am looking for a solution to play three different videos, in sync, to three different monitors. This is a hardware and software solution, my first stop is to work out if vMix is able to play three different videos at the same time, then playout. Not a lot of infomration given here, but I very much appreciate any input from the community. Thanks!
Joined: 4/23/2017(UTC) Posts: 1,488  Location: Germany Thanks: 3 times Was thanked: 197 time(s) in 177 post(s)
Two approaches. #1 create a multiview in 4k and output the videos in each quarter. Enable NDI on the output or send over a card. Split/crop the signal at the receiving side.
#2 Enable NDI per Input in the settings and use NDI Monitor to see the sources on the far end.
You may want to have a shortcut to start the videos in parallel.
Joined: 11/23/2020(UTC) Posts: 242  Location: Wichita Thanks: 11 times Was thanked: 32 time(s) in 28 post(s)
The 4K version of vMix allows four outputs, each of which can be a different video stream. Since it also supports more than four audio mix buses you can have separate audio outputs for each of those video feeds.
It's important to ensure that your hardware setup, including your computer's processing power and graphics capabilities, can handle the playback of multiple videos simultaneously. Additionally, you may need appropriate video output devices or capture cards to connect your monitors to the computer running vMix.
