adityabisnis
#1 Posted : Tuesday, July 4, 2023 12:59:09 PM(UTC)
adityabisnis
Indonesia
Dear Friend,
Im using vMix ver 26. When im trying livestreaming on youtube its getting error like this:
ffmpeg started on 2023-07-04 at 09:23:58
Report written to "C:\ProgramData\vMix\streaming\streaming1 20230704-092358.log"
Command line:
"C:\\Program Files (x86)\\vMix\\streaming\\ffmpeg2.exe" -report -rtbufsize 128M -f dshow -i "video=vMix Video YV12:audio=vMix Audio" -codec:v libx264 -s:v 1920x1080 -pix_fmt:v yuv420p -threads 4 -bufsize:v 4500k -g:v 60 -preset:v veryfast -profile:v baseline -level:v 3.1 -b:v 4500k -maxrate:v 4950k -codec:a aac -b:a 128k -strict -2 -rtmp_flashver "FMLE/3.0 (compatible; vMix/26.0.0.44)" -f flv "rtmp://b.rtmp.youtube.com/live2?backup=1/td3b-b917-45vb-pdrg-am3d\x0a"
ffmpeg version 3.3.git Copyright (c) 2000-2017 the FFmpeg developers
built with gcc 4.8.1 (rev2, Built by MinGW-W64 project)
configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-nvenc --cpu=i686
libavutil 55. 76.100 / 55. 76.100
libavcodec 57.106.101 / 57.106.101
libavformat 57. 82.101 / 57. 82.101
libavdevice 57. 8.101 / 57. 8.101
libavfilter 6.105.100 / 6.105.100
libswscale 4. 7.103 / 4. 7.103
libswresample 2. 8.100 / 2. 8.100
libpostproc 54. 6.100 / 54. 6.100
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio':
Duration: N/A, start: 2185.094000, bitrate: 1536 kb/s
Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1920x1080, 29.97 fps, 29.97 tbr, 10000k tbn, 10000k tbc
Stream #0:1: Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s
[tcp @ 0538ca00] TCP Buffer has been set to 11570176 bytes
: I/O error
i already bypass firewall in my office, and still cannot livestreaming via youtube on vmix
#2 Posted : Tuesday, July 4, 2023 8:10:53 PM(UTC)
@ adityabisnis
The "I/O error" at the end would indicate that the stream is not getting through to the destination server, typically due to antivirus or security software at your end blocking it, but could also be due to invalid credentials (URL and password) but that is less likely in this case otherwise there would normally be a return message from the server along the lines of "not permitted".
