raugert
#1 Posted : Sunday, February 2, 2020 10:01:20 AM(UTC)
raugert
Canada
Currently there is no easy way to know if a script is running in vMix. It would be nice to have buttons in StreamDeck or other devices, as well as third party apps, show a "tally" when a script is actually running.
Please support this request to add Script "running" status to activators and API XML.
thanks,
Richard
stigaard
#2 Posted : Sunday, February 2, 2020 6:57:17 PM(UTC)
stigaard
Denmark
+1
TFMG
#3 Posted : Thursday, February 6, 2020 2:42:02 PM(UTC)
TFMG
Views messages in topic : 42
+1
stevespaw
#4 Posted : Thursday, February 6, 2020 11:56:04 PM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
+1
This is a source of workarounds now.
vmixLove33
#5 Posted : Saturday, October 8, 2022 3:13:32 AM(UTC)
vmixLove33
+1 - for exact same reasons on OP, would like to have something SHOW me when a script is running (ie like one of my buttons on my Companion -> StreamDeck).
I have yet to find a (reasonable) way to workaround this, short of vMIX adding this info.
tks
#6 Posted : Saturday, October 8, 2022 3:15:18 AM(UTC)
tks
put the instruction for an activator or alike within the script itself ? Then you will also be able to specify which script is running ;-)
Gunnar
#7 Posted : Sunday, October 23, 2022 9:02:19 PM(UTC)
Gunnar
Sweden
+1
jet
#8 Posted : Tuesday, October 25, 2022 5:34:02 PM(UTC)
jet
Was thanked: 24 time(s) in 22 post(s)
+1
Nigel.Mercer
#9 Posted: : Wednesday, June 28, 2023 7:50:07 PM(UTC)
Nigel.Mercer
Forum Rank:: Member
South Africa
+1
gpdipalmerahtimur
#10 Posted : Wednesday, June 28, 2023 10:29:35 PM(UTC)
gpdipalmerahtimur
Indonesia
+1
ovonder
#11 Posted : Monday, July 3, 2023 8:33:22 PM(UTC)
ovonder
+1
fva
#12 Posted : Saturday, August 19, 2023 5:46:28 AM(UTC)
fva
Brazil
+1
Mano Bakker
#13 Posted : Monday, August 28, 2023 7:48:31 PM(UTC)
Mano Bakker
Netherlands
+1
Video-Chopper
#14 Posted : Sunday, November 19, 2023 4:23:18 AM(UTC)
Video-Chopper
+1
I hope vMix 27 has something that addresses this!!
In the meantime, has anyone figured out a workaround for this? I have explored streamdeck, companion, vMix, etc. and still have not found any solid ways of capturing this data via XML, and have found no clear API functions to accomplish this.
There has to be some kind of internal information for the script status for Running vs Stopped, right? And if so, how can we find that?
This would be a HUGE addition for those of us that rely on a large amount of scripts for our broadcasts.
#15 Posted : Sunday, November 19, 2023 4:49:35 AM(UTC)
Originally Posted by: Video-Chopper Go to Quoted Post
+1
Believe the issue in providing such a feature is how to implement which script is actually running especially if there is multiple scripts running at the same time out of a large list of scripts
Maybe one can build some sort a status within a (vb.net) script itself as pointed out before (put the instruction for an activator or alike within the script itself ? Then you will also be able to specify which script is running ;-) )
Scripts also stop running if an error is encountered within it
Salvatore
#16 Posted : Tuesday, November 21, 2023 4:02:32 AM(UTC)
Salvatore
Italy
Was thanked: 12 time(s) in 10 post(s)
Use a countdown that triggers an alarm at 0.
Include an additional command to your script that causes the countdown to start again and again
so that it never reaches 0 - unless the script stops.
If the countdown runs to 0 it triggers an alarm:
1. Add Input --> Title --> Timer Centre.gtzip
2. Open Title Editor (right click on Input "Timer Centre.gtzip")
3. go to “Settings” and set the “Duration” (choose the time higher than your countdown time, for example) to “00:00:30”
4. Confirm with Okay
5. Go to "Input Settings" (Click on the cog wheel symbol from "Timer Centre.gtzip") and create a "Trigger" for OnCountdownComplet:
e.g. Trigger: OnCountdownComplet / Function: Prevwieinput / Input: "Timer Centre.gtzip"
Extend your script with:
Code:
API.Function("ChangeCountdown",Input:="Timer Centre.gtzip", SelectedIndex:="0", Value:="00:05")
API.Function("StartCountdown", Input:="Timer Centre.gtzip", SelectedIndex:="0")
I didn't want that my countdown constantly will be reset and set it to every 10 seconds:
Code:
do while true
'always when the digit of the last number of the seconds of the current time is at 0
'(i.e. every 10 seconds)
dim checkSeconds as string = Double.Parse(DateTime.Now.ToString(“ss”).Substring(1,1))
if (checkSeconds = "0")
   API.Function("ChangeCountdown",Input:="Timer Centre.gtzip", SelectedIndex:="0", Value:="00:13")
end if
Or you can also Check the value of the Countdown Time and restart the Countdown If it is under 3 sec
kirik
#17 Posted : Monday, April 21, 2025 3:26:00 AM(UTC)
kirik
Russian Federation
The topic is still relevant. Add information about the script state (run/stopped/error) to the API.
The solution with a timer is very strange and not very serious.
And also similarly about the error in the STREAM section
Тема до сих пор актуальна. Добавить в апи информацию о состоянии скрипта (запущен/остановлен/ошибка).
Решение с помощью таймера - очень странно и не очень серьёзно.
А также аналогично об ошибке в разделе СТРИМ
