engelschall
#1 Posted : Saturday, July 1, 2023 8:18:20 PM(UTC)
engelschall
Germany
Was thanked: 33 time(s) in 17 post(s)
vMix allows one to configure the port of the HTTP API (default 8088) under Settings / Web Controller. Unfortunately, the TCP API is hard-coded to be 8099. This is cruel, as we, on each of two machines, run two vMix instances and want to control them via Bitfocus Companion. Unfortunately, as Companion uses the TCP API (and not the HTTP API, as it has no events) there is no chance to control the second vMix instances. Please be so kind and allow one to also configure the TCP API port under Settings / Web Controller and just the HTTP API port. Thanks!
PS: Similarily, please allow one to configure the IP address where the HTTP API and TCP API ports are listening. This would allow one to select only 127.0.0.1 or a particular Ethernet card or all (the current behavior) with 0.0.0.0.
