Systems
Ultimate PC for Vmix with 20-30 input
Joined: 3/12/2020(UTC) Posts: 6  Location: Hanoi Thanks: 3 times
I'm looking to build a vmix PC with about 30 input sdi with w790 mainboard, Intel Xeon W3400/2400 and GPU Quadro A5000. I don't know if vmix has support to optimize for that hardware? Or can someone suggest me how to build a PC vmix around 24-30 inputs (x3-4 Decklink Quad) .png)
Joined: 9/10/2015(UTC) Posts: 139  Thanks: 2 times Was thanked: 36 time(s) in 32 post(s)
You won't like this answer (and as a vMix enthusiast I hate to say it) but that many hardware inputs isn't well suited for vMix. And it's not vMix's fault either- general purpose PC hardware just doesn't fit this use case well. I run a 16 input machine with an A6000 and it chokes sometimes. (This is due largely to my build being a dual socket so NUMA / the CPU interconnect fabric is being largely tapped out.) Every few years Netflix releases slides about how they improve their architecture to work better on multi CPU machines. It's worth a glance: https://papers.freebsd.o...eebsd-400gbps-slides.pdfIf you were to try and do it, you've picked the right CPU (super high PCIe lane count).
Joined: 2/8/2023(UTC) Posts: 24  Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
Systems
