vmix is great software for playout but i have problem with after effect vr template and vmix , i have vmix pro and creat studieo template with after effect and blackmagic capture card but when add the talent in after i cant connect after to vmix for move talent to vmix and slide talent in vmix with ndi
Joined: 6/29/2011(UTC) Posts: 316   Location: Florida Thanks: 6 times Was thanked: 35 time(s) in 34 post(s)
You should post this in General Support, Second, sounds like you're doing this the hard way, why not just render out the set as a video file and load as background in vmix. It would be helpful if you were more descriptive and uploaded screen shots.
Maybe you are adding the background the wrong way....are you using the Virtual Set template to do this, and is the talent on a green or blue background.....maybe you should do a google search or youtube search for using green screen in vmix, or using a virtual studio Take a look at this video https://www.facebook.com/watch/?v=373859086729015
