NDI
Ndi output sound then the feed dies
Joined: 5/28/2023(UTC) Posts: 5  Location: South Carolina
Stream out via nvidia to a srt encoder. Also output local network with ndi to a few devices running ndi monitor. A windows 11 intel computer stick, an iPad and an intel laptop. Worked fine last couple of years. Lately runs when first started for a few minutes then sound disappears and then lose ability to find the NDI Vmix sources on network until Vmix is restarted. Have VU sound bars activated which just disappear when sound does. No problem with any recordings or other output. NDI inputs work fine from multiple sources. The NDI output just dies.
Thanks.
Tested network, settings and then tried a different test computer. Different computer worked perfectly. Uninstalled and reinstalled Vmix. Seems to be some kind of a corruption that only effected NDI output. In case someone comes across a similar problem, a simple reinstall appears to solve the problem for now.
NDI
