phaedrux
#1 Posted : Thursday, June 15, 2023 6:32:40 AM(UTC)
phaedrux
Canada
Hello, I'm having an issue with using the multicorder on vmix max, which I did not have on the trial.
I am trying to use the multicorder to record all 4 outputs at the same time. The reason for recording the outputs rather than the source directly, is that the source feeds are NDI HX2 streams that tend to breakup when being recorded directly. The workaround was to set the NDI sources as outputs and then record the outputs. This all worked when tested with the trial, but after upgrading to the vmix max subscription it no longer works. Only the first output is recorded, but it still produces 4 files, each file is just a duplicate of the same source though.
Any idea what is going on?
#2 Posted : Thursday, June 15, 2023 7:17:43 AM(UTC)
One can not "upgrade" from a trial to a pro or max as they are functionally the same (trial = pro or max)
phaedrux
#3 Posted : Thursday, June 15, 2023 7:35:15 AM(UTC)
phaedrux
Canada
I think the issue was that in the output settings I didn't have input 1 2 3 4 chosen for output 1 2 3 4. Which is odd, because I don't remember doing that when testing with the trial. Maybe it got reset when I subscribed as along with the registration there was a vmix version update installed at the same time. I wonder if that reset it? At any rate, I think it's working now.
nikosman88
#4 Posted : Thursday, June 15, 2023 10:44:01 AM(UTC)
nikosman88
Greece
Hello. If you do the way you say, how do you do output for the active pgm/output, for example for streaming or recording the whole mixed show? Am i missing something?
phaedrux
#5 Posted : Thursday, June 15, 2023 2:17:21 PM(UTC)
phaedrux
Canada
In my case vmix is just doing iso recording and nothing more.
thanks 1 user thanked phaedrux for this useful post.
nikosman88 on 6/15/2023(UTC)
