Achieve a "soft focus" like to Zoom's "Touch Up Appearance"?
I have a 67-year old client who likes the Zoom "Touch Up My Appearance" feature because it hides her wrinkles. Is there anyway to achieve the same soft focus effect in vMix?
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: CorgVMix  I have a 67-year old client who likes the Zoom "Touch Up My Appearance" feature because it hides her wrinkles. Is there anyway to achieve the same soft focus effect in vMix? Wrinkles are engraved smiles
Joined: 8/10/2022(UTC) Posts: 4  Location: Oregon Thanks: 2 times
Originally Posted by: CorgVMix  I have a 67-year old client who likes the Zoom "Touch Up My Appearance" feature because it hides her wrinkles. Is there anyway to achieve the same soft focus effect in vMix? I don't have the answer for vMix integration, but if a little extra latency isn't an issue, you might be able to run it through some external software (TouchDesigner comes to mind) and send it back into vMix as an NDI send. You might even be able to set up a dummy zoom meeting, send the raw feed there to be touched up, and then send that via NDI into vMix instead. It's janky, but if your client insists on it, that's my best idea at a work around.
I know this is an old post, but you can do this by installing CyberLink PerfectCam from https://www.cyberlink.com/products/perfectcam and then 1) letting PerfectCam use your physical camera, and 2) using the PerfectCam virtual camera for the vMix input. This provides a PerfectCam sidebar (outside the vMix application) that has a slider for Skin Smoothing and other "Makeup" sliders (lipstick, blush, eye shadow, etc.) It also provides support for virtual backgrounds including Blur PerfectCam has a free trial, and is then $50/year. There are a few YouTube videos on this, including: https://www.youtube.com/watch?v=rAyTV7_PCy0 and https://www.youtube.com/watch?v=1FJztcnwsWoI tested this and it seems to work pretty well / as advertised. PerfectCam seems to use about 4% of the CPU (on a little desktop with an AMD Ryzen 7 Pro 4750GE with integrated Radeon Graphics (i.e. no discrete GPU).
