drt
#1 Posted : Monday, June 12, 2023 11:31:38 PM(UTC)
drt
Philippines
Hello there, can anyone teach me how do i smooth my merge like the move transition on (obs). Thank you for your response.
#2 Posted : Tuesday, June 13, 2023 12:17:15 AM(UTC)
Originally Posted by: drt Go to Quoted Post
Hello there, can anyone teach me how do i smooth my merge like the move transition on (obs). Thank you for your responce.
Can think of a few things to "smooth your merge" but would not be vMix appropriate LOL
Advice you to check out some vMix tutorial videos on their Youtube channel
Anders
#3 Posted : Tuesday, June 13, 2023 12:29:21 AM(UTC)
Anders
Was thanked: 12 time(s) in 9 post(s)
drt
#4 Posted : Tuesday, June 13, 2023 12:39:54 AM(UTC)
drt
Philippines
like this
#5 Posted : Tuesday, June 13, 2023 3:26:22 AM(UTC)
like this
the mentioned video is classical merging but with some mix inputs (just to change some individual items easier)
basically have multiple inputs containing the same layers but in different positions and do a merge between them, they will animate from one layout to the other
https://www.youtube.com/...?search_query=vmix+merge
drt on 6/13/2023(UTC)
drt
#6 Posted : Tuesday, June 13, 2023 12:24:17 PM(UTC)
drt
Philippines
like this
is it possible way to not fading on merge?
drt
#7 Posted : Tuesday, June 13, 2023 12:27:22 PM(UTC)
drt
Philippines
is it possible to not fading on merge?
vmixgreg
#8 Posted : Wednesday, June 14, 2023 3:08:55 AM(UTC)
vmixgreg
Rank: Staff
Groups: Registered, Moderator
Was thanked: 22 time(s) in 21 post(s)
Fades only occur on a Merge if you cross layers from lower to higher, otherwise, the higher layer stays solid.
As such, there are "tricks" you can use to change the destination Input to be on layer 10, for a "clean" Merge effect as explained in this third party video from Hym Pawn:
vMix Greg
drt
#9 Posted : Wednesday, June 14, 2023 3:29:55 PM(UTC)
drt
Philippines
i would like to do this, is there's need a triggers on this one?
#10 Posted : Wednesday, June 14, 2023 5:31:37 PM(UTC)
no need for triggers. please follow the advice allready given and practise with it
sinc747 on 6/15/2023(UTC)
