GOYO AI denoise free VST3 plugin
Joined: 3/30/2011(UTC) Posts: 311  Location: Portugal Thanks: 360 times Was thanked: 37 time(s) in 31 post(s)
Originally Posted by: PFBM  hi !!
check this out !!
Great Free Plugin !!
Cheers,
PFBM Posting this once should be enough not ? and personally not inclined to click this type of link without better information
hi ! I posted in 2 areas for different reasons.... 1 - as a vst3 plugin 2 - as a SDK to be able for the vmix developers put it natively inside Some testing..... PFBM Originally Posted by: doggy  Originally Posted by: PFBM  hi !!
check this out !!
Cheers,
Ha! I just found out about it and tested it, it worked really well so I logged on to recommend as well! Also, I have a question - Why some VST3 plug-ins don't fit/scale correctly in their window? They show up cropped to the editor window size so some functions are out of view and unavailable. I added 2 examples here, if they don't show please look in the link. My other plugins show up fine, and I haven't encountered this reported anywhere else or how to fix it. exaple jpegs
