joedemax
#1 Posted : Friday, June 2, 2023 11:45:31 PM(UTC)
joedemax
Was thanked: 9 time(s) in 5 post(s)
Hi all,
I don't post here all that often but just wanted to share with you that our new version of Central Control, 3.1, has been released.
Flex Macros
Rather than a list with delays, we've used a timeline. Actions just get dragged and dropped as if they were video clips. Fader levels etc can be set over the duration of a clip.
Flex Editor
New Rundown
Formerly Rundown Clock, Central Control Rundown allows you to create a Rundown using Google Sheets or Excel and either automate your show based on time of day, or manually step through it.
Rundown
Teleprompter Remote
The Teleprompter Remote allows you to remotely control our prompter from another instance of Central Control, or build your own controller with the TCP API.
Variables
Variables can be used all over the app - in place of command params, to conditionally execute commands, set from timecode, displayed in the prompter etc etc
That's all for now!
Joe
