Instant Replay
Replay records BLACK randomly
Joined: 6/14/2017(UTC) Views messages in topic : 3   Location: Sweden
We have used Replay for many years and sometimes it has been a little buggy but now on our TWO main-computers (one ASUS with i9 and 3080ti plus a 3070ti) we get segment with black recordings on the timeline - they vary from 0.2s to 20 seconds and appear randomly. Our fat production computer is at max 3% CPU and 10% GPU plus we use Resizable BAR. We really need help with this.
/Gunnar, Sweden
Joined: 6/29/2018(UTC) Posts: 19  Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Hello, have you been able to solve it, we have the same problem of black blocks in the random recording, the disks are SSD. the input signals are 4 NDI and we return a full -NDI signal for mixing in the realization system
Joined: 2/23/2019(UTC) Posts: 139  Thanks: 20 times Was thanked: 29 time(s) in 26 post(s)
Replay does need a fast drive, and a drive that stays fast after long periods of writing.
I used a Crucial P3 Plus NVME M.2 SSD in a new build. It's claimed 4200MB/s write speed should be plenty for the around 500 Mb/s needed by four channels of replay but it failed. I found that after replay had been recording for something like 30 minutes, the average write speed dropped to around 75MB/s (600Mb/s) with frequent slow points that caused the replays to include black frames. None of the reviews I'd read mentioned this as they hadn't done a long enough write to hit the limit, eventually I found one review that reported it. I replaced it with a different SSD and all has been fine since.
You can keep an eye on the disk write speed in task manager to see if it is slowing down.
@rich, what drive did you replace it with? I'm trying to avoid the same problem.
Instant Replay
