federicolang
#1 Posted : Saturday, May 20, 2023 1:37:14 PM(UTC)
federicolang
Costa Rica
Hi, I just had a problem with one recording.
I didn`t realize that the multicorder was set to AVI MagicYUV and the disk I was writing to was slower than needed. I recorded a 1:30 hour podcast with 3 cameras+output of an important and irreplaceble guest just to realize the day later that the files had dropped maybe 70% of all the frames. Basically my recording was useless and I lost the client.
I would also recommend presetting the multicorder to "MP4" so that this is more difficult to happen.
I know this was totally my fault for not checking on the settings, but maybe you could ad a yellow "state" to the multicorder button so it will flash if loosing frames, as the streaming button does.
Thanks! love your product.
federicolang
#2 Posted : Monday, May 22, 2023 8:57:31 AM(UTC)
federicolang
Costa Rica
Follow up on this... Also it would be great to have the same feature on the recording button as well, no only multicorder. Lets say if you are dropping more than 2 or 3 frames per second then start blinking in yellow.
mavik
#3 Posted : Monday, May 22, 2023 7:53:11 PM(UTC)
mavik
+1
