Joined: 3/30/2023(UTC) Posts: 126  Location: Chicago Thanks: 11 times Was thanked: 6 time(s) in 5 post(s)
I had ChatGPT create the following script. However, there are some syntax errors and I'd like to ask for any assistance with this I can get. Although I used to code, many years ago, I've not touched scripting in anyway meaningful for a long time so please understand why I reach out.
Here's the code:
Function JoystickMove() 'Get the current position of the layer Dim x As Integer = Layer(1).PositionX Dim y As Integer = Layer(1).PositionY
'Get the current scale of the layer Dim scaleX As Integer = Layer(1).ScaleX Dim scaleY As Integer = Layer(1).ScaleY
'Get the joystick input values Dim joyX As Integer = Joystick(1).X Dim joyY As Integer = Joystick(1).Y
'Calculate the new position of the layer based on joystick input x += joyX * 10 y += joyY * 10
'Calculate the new scale of the layer based on joystick input scaleX += joyX * 2 scaleY += joyY * 2
'Set the new position and scale of the layer Layer(1).PositionX = x Layer(1).PositionY = y Layer(1).ScaleX = scaleX Layer(1).ScaleY = scaleY
End Function
'Call the JoystickMove function every frame (30 times per second) AddPeriodicCallback("JoystickMove", "JoystickMove", 33)
So, looks like it *should* be good but it's throwing an error on the End Function.
Any advice would be appreciated. It's unfortunate that the vMix developers have left this feature (joystick positioner) out of the app and have the community rely on it's own devices to implement.
Thanks in advance.
