enzostrano
#1 Posted : Sunday, May 14, 2023 10:18:17 AM(UTC)
enzostrano
Can you help or suggest a list of good 8 ports plus switches with Poe that I should buy to use with NDI cameras and multiple NDI laptops?
Definitely unmanaged as it will be used in clients locations.
Also, i was told with a minimum speed capacity of 120gigabits.
Im good at many things but when it come to network, not my forte.
Budget £500 or less.
mavik
#2 Posted : Thursday, May 18, 2023 5:41:19 AM(UTC)
mavik
Netgear AV line switches. HP or ZyXel should do as well. If you know RouterOS and won't mind using it, Mikrotik would be an option as well. But if you don't know it and networking isn't yours Mikrotik is nothing for ya.
