RichShumaker
#1 Posted : Wednesday, May 10, 2023 1:28:48 PM(UTC)
RichShumaker
Was thanked: 28 time(s) in 23 post(s)
More Effects Tab stuff, please.
So far this Tab has been amazing. I use the gaussian blur to grind older GPU's to a halt.
Word of warning you will lock your older system up if you are not careful.
I would love the nVidia Broadcast effects in vMix(specifically the background remover). Yes this would require a 2060 or newer nVidia GPU.
Also it would be amazing if you could somehow have the Photoshop Blending Modes.
Here is a list of a few
Blending Modes are: Normal, Dissolve, Darken, Multiply, Color Burn, Darker Color, Lighten, Screen, Color Dodge, Lighter Color, ...
This Blending would require Layers and probably a new kind of Input.
A Blending Input where all the layers with Blending Effects would than activate and work.
If you have 3 layers with Multiply it would build on top of each other just like in Photoshop.
Also you could turn off the Effect and turn it on and get even more amazing looks.
Oh and I am going to put in a Feature Request to be able to control Effects with Commands and Shortcuts.
This request is about More Effects with Specific Ideas.
