jermanprod
#1 Posted : Friday, April 21, 2023 10:58:25 AM(UTC)
jermanprod
I'd like to see the Cut button on the input thumbnails to be moved from its current position or removed entirely. The problem is that it's dangerously close to the audio button. If you go to hit the audio button, you can easily slip and hit cut instead. It's happened to me as the event producer where a guest's audio became problematic and I quickly tried to mouse over the audio button to silence them. But, I overshot the button by a hair and hit cut instead creating an unwanted transition during the show. How many people even use the cut button from the input thumbnail. Would be interesting to hear from other users about this.
Perhaps, let the users customize the shortcut buttons for the input thumbnails through a menu setting.
